Going to get the Audiobahn A8000T but need help choosing a sub
Username: Genocide43110
OH
Ok I'm pretty set on the Audiobahn A8000T amp. But I was thinking of getting the ALUIM1ON found here http://www.cardomain.com/item/ABNALUM10N What I am wondering if it will work with the amp. If I wire it up this way http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=6o hm_dvc&x=157&y=6 it will be wired to run at 3 ohms but I don't know if it will work with the amp as it is 2 ohm stable. I have around $380 to buy the amp, sub, and a box. Basically I want the loudest system I can get for the money. If anyone has any better suggestions for a sub (or amp) I'd like to hear it. Also I've previously had 2 Audiobahn 15" subs and liked them so that's why I am leaning towards all Audiobahn stuff.
Username: J_baby15
Kentucky
Post Number: 89
The amp is 2ohm stable, so you can run it above 2ohm. I wouldnt get Audiobahn subs, they're not very good, but their i like the amps, especially the A8000T. Check ebay, you can get an A8000T shipped for about 130. Look into some better subs, you'll be amazed if you thought the audiobahns sounded good.
Username: Dustin3
Tigard, Or U.S.
Post Number: 839
get 2 comp vrs. dual 2 ohm version and wire it to 2 ohms. you will be very happy with this
Username: Sw9152
Michigan
Post Number: 373
NO STAY AWAY FROM AUDIOBAHN SUBS!!! AMP IS GOOD, I WOULD GET ASCENDANT AUDIO ARSENAL SUBWOOFER. AS LOUD OR LOUDER THAN AUDIOBAHNS AND WAYYY BETTER SOUND QUALITY. ALSO IS ON SALE RIGHT NOW BECAUSE IT IS ON BACK ORDER, BUT IT IS WORTH THE FEW WEEK WAIT. WWW.ASCENDANTAUDIO.COM
Username: Dustin3
Tigard, Or U.S.
Post Number: 840
you can get 2 for 200 bucks, like the 1 audioburn one, or if one sub, get the dual 4 ohm version
Username: J_baby15
Kentucky
Post Number: 93
Whatever you do dont get the Audiobahn sub. What size subs you looking for? and how many?
OH
Im getting the amp off ebay from here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9714365092&ssPageName=MER C_VIC_RSCC_Pr4_PcY_BIN_Stores_IT Also you said to get some comp vrs. Are these what you're talking about? http://cgi.ebay.com/2-Kicker-CVR10-2006-Comp-VR-Subwoofers-10-NEW-CVR-DVC_W0QQit emZ9714017974QQcategoryZ39772QQrdZ1QQcmdZViewItem Also I basically have $255 to buy the sub(s) and box.
OH
Also I'm looking for basically one sub and don't really want 15"'s again because the ones I had took up almost all of my trunk space.
Username: Shman
Michigan United States
Post Number: 34
you need 2 12" cvrs dual 2 ohm
Username: Dustin3
Tigard, Or U.S.
Post Number: 843
lee - yes those are the ones i am talking about. Those are the 10 inch. get 2 12" and you'll be set. get the dual 2 ohm version
OH
Post Number: 9
I also read on here that the amp only puts out around 750 watts instead of the 800. Is this true? If so I was now looking at getting 1 L7 here: http://cgi.ebay.com/KICKER-S12L7-CAR-AUDIO-L7-SOLOBARIC-12-SUBWOOFER-04_W0QQitem Z9711102393QQcategoryZ39777QQrdZ1QQcmdZViewItem
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 738
i just got that amp for 91 bucks shipped brand new off ebay for my second system it is a nice amp you will be pleased w/ it.
OH
Post Number: 10
How about these? http://cgi.ebay.com/PAIR-2-NEW-05-KICKER-CVR12-COMP-VR-12-2-ohm-1000-W_W0QQitemZ 9715235888QQcategoryZ39777QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Also are these subs 800 watts rms each or together? That's one other thing I always wondered about.
Username: Ctmike
Ct.
Post Number: 299
400wrms each.
OH
Post Number: 11
Ok, so if I wired them in series then would they be able to handle the 800 watts rms the amp is putting out?
Username: Shman
Post Number: 44
definately, the amp is perfect for them
OH
Post Number: 12
Alright but what about 1 L7? I like the way it looks. Plus I'm trying to save trunk space.
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 430
i am getting that amp and a pair of CDT 1215's 4 Ohm DVC....
Username: Sw9152
Michigan
Post Number: 383
the L7 is budget spl sub. if you want clean loud bass, then you want the ascendant audio arsenal. close to as loud, matches your amp perfect, and comes with 3 year warranty for approx $175 shipped. aint no better deal than that.
Username: Drivingreckless
Nuthingsville, Florida United state...
Post Number: 76
i got my two treos tsx 12" for 130 a piece and they hit hard..highly reccomended
OH
Post Number: 13
So it's $15 for shipping on the 12" Arsenal then?
OH
Post Number: 14
Also the 12" Arsenal is only recommended to be running at 500 watts isn't it?
OH
Post Number: 15
SW9152, You said that the L7 is an SPL sub. I read that SPL is basically going for loudness. Im pretty sure that is what I am looking for. But as I said before, would one L7 be able to handle the amp? The L7 is rated at 750 watts RMS and the amp is putting out 800 watts RMS. Also, I'm pretty sure it won't be louder, but will the one L7 be as loud as the two Comp VR's?
