Ported Box-Seperate or Combined Ports??
Username: Joebruce
U.S.A.
Post Number: 369
Which is better,each sub in a seperate chamber with its own port or both in the same chamber with a shared port?? What are the pros and cons of each??
Username: Joebruce
U.S.A.
Post Number: 371
bump
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2520
well actually im not SURE. because spl competition cars often have subs in one chamber and share ports. but puting them in separate chambers adds bracing which is always good. too many subs off axis in the same box can cause cancelation though. guess im just bumping it up for some1 else to answer.
Username: Joebruce
U.S.A.
Post Number: 372
Thanks I'll bump it up again too!
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1096
i wouldnt think that it would matter.. i think the bigger deal is where the port(s) is situated.. and the amount of port area.. but im not sure
Username: Koz1031
Monticello, In United states
Post Number: 430
I've wondered the same thing. I run a dual chamber with a shared final port, and it bumps hard. But would it be better if the shared port was split?? hmmmmmmm?????
Username: Solacedagony
New Jersey US
Post Number: 878
It'd be better to have individual airspace and port. If a sub blows, then your air space/port space doubles, if air/port is shared.
Username: Koz1031
Post Number: 431
kinda what I figured. Thanks Jake.
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 620
this is my opinion........take ketchup pakage squeez 1 side....the other side goes out....visa vers......so when they share the same port/airspace they cause this efect.....
matterfact tweeter did a Sh*tty job at building a sealed box 4 2 10" infinities the didnt build a wall 2 seperate them....they would fight each other an make the subs sound off...at low volumes it sounded good....but turn it up....it was horrible.....dont know if the same princible applies to ported boxes but i would let them have there own seperate space
Username: Rovin
Trinidad & T...
Post Number: 7427
the purpose of having separate chambers is clearly known but the only reason IMO 4 NOT making separate chambers is that ppl r too damn lazy ......
