12" COMP VR vs. JL AUDIO 12W3V3 PLEASE POST ASAP
Username: 69_ohm_stable
Hey guys, I just joined a few days ago and thought that you all would be able to help me with my biggest delima. The blue prints for my next stereo system are complete with one detail missing. I don't know whether to go with 2 Kicker comps or 3 JL W3's. I have an MTX Thunder 942, and it would give the JL's roughly about 300 watts each(which is their RMS) or I could give the comps about 450 watts each (which is 50 watts more than their RMS)I would really appreciate everyones opinions. I plan on buying my subs within the next two weeks. Please give me your thoughts and tell anyone that you know on here to come and post. Thanks guys
Username: Ctmike
Ct.
Post Number: 302
i'd go jl. i have 2 w3 and they sound really good. plus they'll be louder since you're getting 3. kicker in my opinion is only really good for spl, so if you want any type of sq from your setup then try to avoid them.
Username: Sw9152
Michigan
Post Number: 380
i heard a pair of cvr 12s and they sounded real good but i think the jl's would sound a better and would be louder.
Username: Delsole
Post Number: 345
hey ctmike you have the new w3v3's how do they sound
am I gonna need to step up to a HO altenator and a second battery? I also have a 684 for my coaxials.
Username: Adddisorder
Post Number: 146
youll probly need an ho alt, but how many amps is you stock?
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 195
my friend bought 2 12 cvrs an i have 2 jl w3s an he got his runnin of a boss 1600w amp an a dual box i made tuned @ 24hz an i got a dual box a lil smaler than his tuned @ 26hz off a pioneer amp an his is louder for sum reason but iam runnin my subs @ 4ohms a pieace an hes runnin his @ 2ohms a pieace
Username: Sw9152
Michigan
Post Number: 381
i have been running 1200wrms off my original stock ~80a alt for a few months and no problem. and my explorer has 236,000 mi on it. lol
my 942 is supposed to put out 940 watts when bridged at 4 ohms and I know for sure that my 684 puts out 593 watts. I was also considering doing the MTX 7500's. would two of them be better than 3w3s?
Username: Killswitchjd
Post Number: 40
I have two cvr12's and they sound good. Very tight, exact bass. Sealed box is probably why... On an audiobahn a8002t 800x1 at 4 ohms.
Username: J_baby15
Kentucky
Post Number: 100
How much are the new 12 3v3??
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 739
i have 3 12 w3v2 and they will be way louder than 2 kicker comp Vr's i've heard the comp vr's several times and they are very unimpressive. i'm runnin a rockford bd1001 and a 301s for components and i have aboslutely no voltage problems whatsoever on a galant w/ stock alt. the JL's will sound better and w/ 3 will definately be louder.
do you think that 3 jl's will sound better than two MTX 7512's? I have narrowed it down to these two
Username: Ctmike
Ct.
Post Number: 307
two w3's would sound better, so 3 would be a great set up.
