JL 10w6v2 vs. Tre TSX vs. DD 2500
Username: Joebruce
U.S.A.
Post Number: 364
All 10's and all getting 500w rms which would be the better SPL sub? Compare them in SQ,SPL,and SQL. Please rate them in order 1,2,3 in all catagories.
Username: B101
Queen City, NC USA
Post Number: 2370
ummmm:
spl: dd, tsx, w6
sq: w6, tsx, dd
sql: tsx, dd, w6
Username: Night_mirage
AmmanJordan
Post Number: 237
thanks B
but TWiZTiD who said the 10W6 is 500RMS
its 400
Username: Mateo
Post Number: 22
he was saying that whatever he get will be recieveing 500wrms. he wasnt saying that the W6 was 500wrms.
Username: Joebruce
U.S.A.
Post Number: 365
Yea thats what i was saying.JL subs can easily take 500 even tho they are rms at 400.
B-Thank you im pretty sure im going to go with the treo tsx now.Thats exactly what i was looking for a sub that has more spl than a w6 and almost as good sq.
Username: B101
Queen City, NC USA
Post Number: 2394
no problem man, keep us informed.. :-) get a 1200d, u will be impressed... always remember the chargin system.
Username: Joebruce
U.S.A.
Post Number: 367
Actually Ive changed my mind again Im going to go with 2 10" treo ssi instead. I was looking on thier website and they recomend 300-750w rms and Ill be giving them both 500w rms so i think it will work out pretty good. And im gonna throw em in a ported enclosure instead of sealed. Just to make sure I e-mailed them and asked if 500w will be enogh,im just waiting for them to write back.Thanks for everyones input and advice.
Username: Suleman36
Maryland U.S.A.
Post Number: 3572
Great Choice, ive decided to go with 10's also due to space in my trunk. I am going to probably get 1 or 2 10 SSI's and go ported with a custom box built.
So far its SSI 10 or maybe another 10 that has similar output and SQ.
Username: Joebruce
U.S.A.
Post Number: 368
Hey MO do you think 500w rms will be enough to power them properly?
Username: Suleman36
Maryland U.S.A.
Post Number: 3574
Definetly
Username: Joebruce
U.S.A.
Post Number: 370
I think i remember reading in another post that you said you know someone with 1 10" treo ssi in a convertable that is hitting 130db,am i right? If that was you what amp is it being powered with and what size box is it in? Also what do you think 2 10's would hit in rec. ported enclosure? Thats pretty damn good for 1 10" if i read that correctly!
