Zapco vs JL
Username: Ogduncan
Post Number: 20
which amp to power 2 jl 10w6v2 the zapco c2k 6.0x or the 1000/1
Username: Ogduncan
Post Number: 21
also i can get both at a similare price
Username: Ctmike
Ct.
Post Number: 286
for the same price, or near it, definately the jl.
Username: Jonathan_f
GA USA
Post Number: 5938
C2k, all day every day :-) Much better amp.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6503
yep, jl's are good but not as good as zapco
Los Angeles, CA USA
Post Number: 3668
i know that the zapco is a much better amp than the jl but will there be big difference in audio?
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 598
I can bet you wouldnt be able to hear anything different in audio quality when both amps are hooked up
Username: Ogduncan
Post Number: 22
what makes amps like arc and zapco better than jl. I heard that under .1% you cant hear any difference. All of them seem to be below .1%
GA USA
Post Number: 5939
Build quality, material quality. Matched for equal power output (assuming both are within their limits), you won't hear a difference between amplifiers anyway.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1800
for subs, i doubt you can tell any difference between the two.. speakers, maybe...
