Cut through need good subs for spl
Username: Alastaka
Post Number: 101
im doing a cut through in my truck and im looking for either 1 or 2 15's ive looked at memphis and treo and re and rockford.. they will be powered by 2 rockfordfosgate t2000.1's and i have about 1000 i can spend on subs so i was wondering what subs i should go with for all of that... looking for loud but also a daliy driver
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 886
1 treo SSx 15 or 2 treo SSi 15s.
also ull need a 300amp alternator and a few batteries...just so you know.
Username: Sw9152
Michigan
Post Number: 338
the new re xxx looks awesome, but have not heard one. i can speak for eclipse 15" titanium, i love it, one of the top sql subs imo. they are actually 1500 rms each not 750 though, eclipse-web.com rated them per voice coil.
Username: Alastaka
Post Number: 103
what is the price on the ssx and the xxx's
Username: Alastaka
Post Number: 104
what about the mephis m3mojo they have a 92 db sensativity
Username: Alastaka
Post Number: 105
lil help here plz
Username: Sw9152
Michigan
Post Number: 345
pretty sure the new xxx 12" is $630 shipped. don't get the mojo, there is better out there.
Username: Sw9152
Michigan
Post Number: 346
it is a little out of your price range but the new re audio xmx can handle 5000 rms weighs 81 pounds and has 8.9 inches of excursion. only $5000. no pics but specs on caraudiomag.com in the buyer guide thing.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1606
maybe 2 AA havocs, im sure they could handle all of those rf amps.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2467
either 2 15 havocs or 2 audioque HD15s. please get the AQ's ive been dieing for somebody to. they will beat the sh!t out of your car with 2000w rms.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6481
Crystal Comp X's <<<<<<YES
Username: Theweasel
Post Number: 128
can you post the specs link on that new RE sub
SW9152?
Username: Theweasel
Post Number: 129
i want to see the 24" version of that go up against the Jackhammer. hehehehehehehe
Username: Extrmndor3
Chicago, Ill Us
Post Number: 448
i suggest re audio mt will be a great choice for spl one of the best subs for spl and they have decent sq if u tuned correctly ill go wit that if u have those amps or yeah two havocs, i think a single 18 inch can handle 2000 rms, but dont take this advice, ill said go wit re audio mt or xxx or wait for the re audio mx is like 450 for the 12
Chicago, Ill Us
Post Number: 449
i dont llike the way re audio is sellin their subs everytime their subs get expensive everytime they take out a new model i saw the car audio mag my 18 sx i bought for 320 shipped like a month ago and its says 519 for my 18 model and i called reaudio and they told me they will have the same sx so why is that price so high
Username: B101
Queen City, NC USA
Post Number: 2362
just do what Jake Papa said.... slap both of them amps to a TREO SSX 12, 15, or 18... :-) 700, 900, 1000$
<<< u said u need loud, but u aint ready for that loudness yet....
How big is your HO alternator and Big3? Ok.. see the point...
The Crystal Comps like CB said...
with 4000rms u better have a 300a alternator or better... plus battery reserve.. :-)
