Bronze Member Username: Drivingreckless
Nuthingsville,
Florida
United state...
Post Number: 60 Registered: Apr-06
Posted on how do u ussually remove the radio of ne car not ne in particullar.... |
Gold Member Username: B101
Queen City,
NC
Post Number: 2341 Registered: Sep-05
Posted on u remove the screws that holds the raido to the dash or frame of the dash... |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1775 Registered: Feb-05
Posted on look for a Haynes or Chilton manual for the car. it'll show you how to get the dash appart and get to everything. very useful books. it all depends on the car though. gotta remove all the trim pieces from around the radio, then get to whatever method is used to hold the radio in. |
