Plez help!!
Username: Thomas_g
NM
Post Number: 196
How do you know how much airspace volume is left in the ported enclosure after you add the sub and the port or vent??
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1769
the sub manufacturer should tell you how much space the sub takes up.
calculate the volume of the port (including the material) just like you would a square or rectangle. LxWxH...and subtract that from the total box airspace.
Username: Thomas_g
NM
Post Number: 198
where would it say on the manual how much space the sub take up? Is it the (vas) or the net displacement? Thanx brandon.
Username: Thomas_g
NM
Post Number: 199
anybody?
