Does it matter where you put the port on an enclosure?
Username: Thomas_g
NM
Post Number: 182
Does it matter where you put the port on an enclosure? Could i put the sub on the front and the slotted port on the side? Thanx.
Username: Terry6405
Sullivan, IN US
Post Number: 671
you can, but it dependes on your vehicle whether or not it will be louder faceing a given direction
Username: Thomas_g
NM
Post Number: 187
I have a 2003 ford focus(not a hatchback). Where can i go to draw a drawing to put on here to show you?
Los Angeles, CA USA
Post Number: 3632
i have my subs firing forward in to the cabin with the trunk sealed. with my ports being in the middle it sounds louder than when i had a slot port with the ports on the outer sides.
Username: Thomas_g
NM
Post Number: 188
ports in the middle where? Like in the middle of the top of the enclosure?
Los Angeles, CA USA
Post Number: 3633
well i have a slot port
Username: Thomas_g
NM
Post Number: 191
Do you have any expirience with making enclosures Treo? Could you help me?
Los Angeles, CA USA
Post Number: 3634
what do you need to know.
Username: Thomas_g
NM
Post Number: 192
Ok i wanna make a slot vent for my enclosure for 1 12" Kicker 05cvr. The manual says to make the enclosure like this: (2.25cuft(63.7)+port displacement 3" by 12.5" port, 20.5" long.) I need help finding out what the outer dimensions should be because i just found out that if i tuned the box to 2.25cuft it would be whatever dimensions, but when i add the port and the sub the cuft of airspace goes down so i need to know the outer dimensions and where to put the port and sub at. Thanx, if you need any info about the sub just tell me....
Username: Thomas_g
NM
Post Number: 195
can anyone help me??
