New member Username: Matt4309Post Number: 1 Registered: Apr-06 | i have just recently bought (2) rockford fosgate T112D4 woofers and ive been looking at different amps to power them and i was wondering if the rockford fosgate T15002 2-channel amp would be a good choice for these subs? |
Gold Member Username: LexuscoopPost Number: 1308 Registered: Dec-05 | whats the RMS on them and the stats on them? |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 891 Registered: Jul-05 | i would get a t10001, they are pretty good amps. if you want to save money get an orion 1200D. |
New member Username: Matt4309Post Number: 2 Registered: Apr-06 | they both run 600rms and 1200peak. i was looking at the T10001 but isnt that a one channel amp? i want just one amp to power both of the subs |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 412 Registered: Dec-05 | it's better for subs to have a mono amp class D and the T10001 will do it ok, you just need to wire it properly, go to www.the12volt.com and press the link woofer wiring |
New member Username: Matt4309Post Number: 3 Registered: Apr-06 | i know it subs are supposed to run only off one channel, i was planning on running one sub of each of the two channels from the 2-channel amp. also the T10001 is only one channel, would i have to split the output from that channel? and will that supply enough rms power to the subs? |
