Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3517 Registered: Feb-05 | After waiting 3 months or so for the ID MAX 12 here is what cardomain emailed me today. Greetings from CarDomain, We have an order for you for the Image Dynamics ID MAX 12 V.3 D2 subwoofer. This item was on factory backorder, and unfortunately we have received news from Image Dynamics that they will no longer be making this product. If there is a different subwoofer we can replace this item for, please let us know. Either way, please let us know what you would like to do with the order. We apologize for any inconvenience this causes. If you have any questions, please do not hesitate to contact us. Best Regards, Sean Wright Product Support Specialist Cardomain Network 800-597-9776 www.cardomain.com I guess i will change my Subwoofer to a JL 12w6v2 or a 15w3v2 / Thats going to be my new setup at this point. |
Gold Member Username: PelonaPerris, California USA Post Number: 1316 Registered: Dec-05 | that sucks azz! so theyr not gona make the idmax nomore? |
Silver Member Username: NemenPost Number: 712 Registered: Dec-05 | sh!t better start looking on ebay for the last few |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3525 Registered: Feb-05 | Im going to now sell my arc audio 1500-xxk amp since the id max project is cancelled. I made a post about this in the amplifiers section. ![]() |
Gold Member Username: RovinTrinidad & T... Post Number: 7299 Registered: Jul-05 | so y don't u buy a 12" idmax anyways from another site cause its still being advertised 4 sale ...... |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3526 Registered: Feb-05 | To be honest im just pissed off with ID in general since they jerked me around for the last 3 months. I could buy it else where from a ebay seller or unauthrozied source, but i just dont want to support them right now. I am changing up things around and going with a smaller amplifier. Most likely another ppi a600.2 or JL 500/1 or X600.1 / Somthing along those lines for now unless somthing else comes up. Ill end up going back to JL since there subs are always great all around. |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 1736 Registered: Feb-05 | other sites don't have them either. |
Gold Member Username: Jonathan_fGA USA Post Number: 5928 Registered: May-04 | Wow, didn't hear that news. On the other hand, I DO believe a newer sub of a higher caliber is coming from them. I thought it was simply going to be the ID Max v4 (and this may be the case). Maybe it's just the v3s that won't be made anymore *shrugs* W6v2 is a great alternative to an ID Max, though. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1323 Registered: Jun-05 | mo that sux man and you just got rid of your w6v2's hats like a huge waste of money i feel for you man |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3531 Registered: Feb-05 | After several hours of research, I have come to the conclusion of going with the SoundSplinter RLP-12 subwoofer and going sealed and then ported. http://www.soundsplinter.com/rlp12_premium_series_12_inch_DIY_subwoofer_informat ion.html Anyone here heard this subwoofer before. It is suppose to be very detailed and get low aswell. Suppose to be in the same league as a w6v2 and idmax. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1325 Registered: Jun-05 | I heard it is good but as sq goes not as good as w6v2 or idmax but i heard it has a great low end and gets loud. I also read someplace that they just buy the baskets off of tc to cut costs just thought i would throw that up there not saying it is a bad thing |
Bronze Member Username: NztunezNelsonNew Zealand Post Number: 43 Registered: Feb-06 | MO...a couple more options...what about a Crystal sub or a Stereo Integrity Mag? They both get great reviews and are often mentioned in the same league as JL and ID. |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3546 Registered: Feb-05 | I havent heard either but ill def consider both. Thanks Im looking at the SS RL-p 12 right now ported How much is the SSI MAG 12 ? |
Bronze Member Username: NanbakatMexico CityMexico Post Number: 33 Registered: Mar-06 | I read some message boards on the Image Dynamics website. The guys who design and build the IDMax sub say that there was a delay with receiving parts they needed to build the last 300 or so 12" IDMaxV3 subs that they had on order. They are going to finish that final round of orders before commencing work on the IDMax V4. The new model should be better than the previous one and be available early this summer (according to the website, anyway). Specs are not available yet. |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 895 Registered: Jul-05 | mo you need to get a treo SSi 12 or 15. more than enough bass and perfect sq. |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3561 Registered: Feb-05 | http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=streetbox%5F12 Im very close to ordering that package. Let me know what you think. Im not sure what its tuned to but its suppose to be perfect for the sub. |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 2475 Registered: Sep-04 | wish i could see what it looks like but i bet it would be great. interested in the review if you get it! |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3562 Registered: Feb-05 | Im going to get that setup with the SSI 12. I called Treo and they said its tuned @ 34hz which is perfect for in car response with that box since you usually loose about 10hz when you put it in a trunk of a car. Im probably not going to buy from mobilesoundworks.com because they are not authorized to sell Treo but my local dealer is about 1 hour away which will be worth the drive im sure. Photo of the Treo HOtbox for the tsx can be found here to give you guys an idea of how nice there box's are. Im sure the SSI 12 Street Box will be nice also. http://www.tamparacing.com/photopost/showphoto.php/photo/27308 |
Gold Member Username: B101Queen City, NC USA Post Number: 2327 Registered: Sep-05 | well this is about as sure as Ive heard you Mo... ![]() |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2800 Registered: Aug-05 | cool. you will love it. ![]() |
