Which Alternator??
Username: Matt12490
Benicia, California USA
Post Number: 589
I got a 89 civic and need a higher output alternator. I searched ebay and came up with 2 different ones:
http://cgi.ebay.com/ebaymotors/88-90-Honda-Civic-High-Output-Alternator-160amps- Wow_W0QQitemZ8044114410QQcategoryZ33573QQrdZ1QQcmdZViewItem
and
http://cgi.ebay.com/ebaymotors/88-91-NEW-HONDA-CIVIC-HI-PERFORMANCE-ALTERNATOR-1 70-AMP_W0QQitemZ8042374690QQcategoryZ33573QQrdZ1QQcmdZViewItem
the second one looks built better and has a 2 year warranty but the first one only has a 1 year warranty. maybe i will just check on iraggi or excessive
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1655
the first one is a rebuilt one. thoes don't tend to last as long from what i hear. i bought a 160 amper from the seller of the second listing, burned it up. not very impressed and have heard some bad things about them.
i'd look at Iraggi or Excessiveamperage.
http://search.stores.ebay.com/Iraggi-Alternator-and-Electronics_civic_W0QQfciZQ2 d1QQfclZ3QQfsnZIraggiQ20AlternatorQ20andQ20ElectronicsQQfsooZ1QQfsopZ1QQfsubZ3QQ ftsZ2QQsaselZ35089818QQsofpZ0
Username: Excessiveamps
Dothan, Alabama Good Ol' U.S...
Post Number: 30
I can custom build you one that will last. I have a group buy going on at ROE right now. I might see if the mods will allow a group buy on here maybe next month. I will check into it to make sure it is okay though.
Username: B101
Queen City, NC USA
Post Number: 2269
Nathan ask the MOD here...
https://www.ecoustics.com/electronics/forum/updates/47093.html
OR HERE
https://www.ecoustics.com/electronics/forum/suggestions/22.html
Username: Matt12490
Post Number: 641
The mod most likely will let you do this. We had a group buy for RE back in December. Let us know because I am very interested.
Post Number: 32
I will get with them later today and see if they are okay with it. I have a group buy going on this month on another forum. If it is okay with them, I will try to have it in May. Thanks for the links.
NaTe
Username: Matt12490
Post Number: 668
bump did you talk to the mod?? and what forum are you having a group buy for right now??
Dothan, Alabama Good Ol U.S....
Post Number: 44
Am I allowed to say it on here ? I will ask about the group buy for ecousitcs right now....
Username: Suleman36
Maryland U.S.A.
Post Number: 3512
Nate, whatsup man. I emailed you a couple of times about my alternator and the wiring. Check it out and get back to me and let me know whats up. Thanks man
