Bronze Member Username: Qslimms
Swanton,
Oh
Usa
Post Number: 37 Registered: Mar-06
Posted on can u run a 2 ch amp to 4 coax speaker in stereo?if u run 2 to each channel for a 2 ohm load so if your amp is 300w x 2 @ 2 ohms you would get it |
Gold Member Username: Tjmutlow
Post Number: 1879 Registered: Sep-05
Posted on yes |
Silver Member Username: Juliob
Santo DomingoDominican Re...
Post Number: 385 Registered: Dec-05
Posted on of course man that's like if you can put 6 people in a van jeje |
Silver Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 950 Registered: Oct-04
Posted on A Lanzar amp can do more than that and you'd get more power from a lanzar amp than you put into it. They are awesome!!! |
Swanton,
Oh
Usa
Post Number: 39 Registered: Mar-06
Posted on lucas do u work 4 lanzar |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 745 Registered: Oct-05
Posted on lol. yea, you are always saying they are so awsome. |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 794 Registered: Mar-04
Posted on His comments have been just a bit over the top -- don't ya think??? Is it really that hard to see he's trying to heckle those of us that like Lanzar? To answer the question - yes, you can run four 4 ohm speakers off a 2 ch amp -- no prob - you just won't be able to fade front-to-rear. |
Tulsa,
Ok
Usa
Post Number: 967 Registered: Oct-04
Posted on or you could sacrifice left to rightbalance and hook it so that you could get front to back fade. And whats wrong with Lanzar? |
Silver Member Username: Killerzracing71
Fredericksburg,
Virginia
United states
Post Number: 523 Registered: Aug-05
Posted on lucas i thought u were a high end guy |
Tulsa,
Ok
Usa
Post Number: 970 Registered: Oct-04
Posted on Just trying to make a point to a Lanzar fanatic. |
Swanton,
Oh
Usa
Post Number: 40 Registered: Mar-06
Posted on i use 2 have a lanzar setup back in high school it beat.that was almost 10 years ago though car audio wasnt wut is 2day though |
