Im buying stuff and need help
Username: Steve_collins
Post Number: 15
im buying subs and im getting a alpine typx fully powerd or should i get a 15inch orion h2 fully powerd. which is better if i cac only get one. and is there anything better for around 250 to 300
Username: Tjmutlow
Post Number: 1906
well, if you buy the h2, i hope it comes with a an orion 2500d, that is what it needs, also an alt upgrade. either way you will prob need alt upgrade, and you do not need to match amp max power to max on sub, just above rms is fine....
Post Number: 16
what would you get im only getting one
Username: Theweasel
Post Number: 114
the type x is nothing to write home about. it has some pretty good sound quality comparable to a w3 or a lower level image dynamics, but the output is sub-par. if you want alpine go with type r.
