Amp for 2 S12L7s
Username: Kyuhl22222
What amp should I purcahse if i am looking to power 2 kicker 12" solo-baric L7s.
Username: Qslimms
Swanton, Oh Usa
Post Number: 35
depends on your budget.me personally id go with a sx1250 or a new zx
i have been looking for those on the internet, what price do you think i should spend for one?
would a kx1200 be enough power?
Username: Qslimms
Swanton, Oh Usa
Post Number: 36
should be their underrated.i got one in my truck.how much u willin 2 spend
Username: Juliob
Santo DomingoDominican Re...
Post Number: 375
if they're dual 4 ohm you should buy hifonics bx2005 and if they're dual 2 ohm, buy viper 2500d and turn the gain down or kicker 2500.1 and keep the gain down
Username: Rovin
Trinidad & T...
Post Number: 7192
ya if they r 4ohms dvc - i would prolly get PPI DCX 1500 ......
i want to spend between 3-400 on the amp. sorry i am new to systems but what is the difference between 2 and 4 ohms and what should i buy?
Username: Juliob
Post Number: 383
better investigate about ohm's law on internet, i'll give a site
www.the12volt.com
Post Number: 10
ok so i think i am going to get 2ohms for the s12L7s but i want to keep my price between 350-450, what does the d class mean and if its only a single channel how does it power 2 subs, (sorry im a newbie)
Username: Rovin
Trinidad & T...
Post Number: 7211
ok trust me
if u want 2 subs buy the 4ohms dvc version & hook it up like this
it is usually cheaper nowadays 2 buy a 1ohm stable amp . Mono amps r better/work out cheaper 2 power subs
its way too much 2 type 2 explain 2 u so read
http://wickedcases.com/tutorials/index.html
& www.bcae1.com ...
