What is the wattage?
Username: Mygame5982
H-TOWN, TEXAS US
Post Number: 82
what is the rms and peak wattage of the planet audio Class D P850D amplifier? plus will it push two 15 inch kicker compvrs?
Username: Tjmutlow
Post Number: 1882
850x1 @ 1ohm but i doubt it will do that on stock system, and not enough power for those subs
H-TOWN, TEXAS US
Post Number: 83
is that rms or peak power? plus what amp should i use to push them?
Username: Ctmike
Ct.
Post Number: 191
what voice coil are they? if there the dual 4 just get any amp that puts out 1000-1200wrms@1ohm.
H-TOWN, TEXAS US
Post Number: 87
bump
come on guys
Username: N2audio
Lawrence, Ks USA
Post Number: 791
unless you're looking to get every last tenth of a dB out of them that PA amp should work fine. Ideally 1000-1200w at 1 ohm would work best, but the difference between that and 850 would be slight.
H-TOWN, TEXAS US
Post Number: 88
is that amp 850 watts rms at one ohm? and what is da peak
H-TOWN, TEXAS US
Post Number: 90
bump
