AWG?
Username: Killer44
Ontario Canada
Post Number: 481
Whats is the lowest size u can go in speaker wire running speakers off an amp ( about 60 watts) like can i use somehting smaller then 20awg? or is there a certain awg where the wire will be to thin...thanx in advance
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 246
suck it up and buy some real speaker wire. it's so cheap, thats something you shouldn't budget over.
Username: Adddisorder
Post Number: 101
i used 12 gauge for 75rms but you could probly get away with 16ormaybe 18
look at the12volt.com for a chart
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11476
for speaker wire? 18-20AWG is ok. I wouldn't go any smaller just to avoid brittle wiring.
for power, use this chart:
http://www.the12volt.com/info/recwirsz.asp
