3 15w6 6ohms
Username: Loc_out
Santa Ana, Ca
Post Number: 341
What amp will push this sub? i was thinking about a 1000\1 but that's only 1000 watts. Please help
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1583
wire then Series/parallel for a 4 ohm load. they are 400 RMS a piece, so a 1000/1 would work fine. you could go with something bigger. 3 500/1's would be nice, lol.
if you wire them parallel/parallel, you'll have a 1 ohm load and could run like an Orion 1200D or Kicker KX1200.1 for a little more power.
Username: Loc_out
Santa Ana, Ca
Post Number: 342
would it be best to run them 4 ohms or 1 ohms?
Username: James1115
Ct
Post Number: 5434
I personally would run them at 4 ohms off a 1000/1 you wont notice much of a difference if any at all between the 1000/1 and a 1200 watt amp. Dude but for real though you don't need those how about selling them to me:-)
Username: Tjmutlow
Post Number: 1822
4ohm then you can use a 2 channel or 1ohm and a mono....
Username: Lewass
Boomfield Hills, MI USA
Post Number: 463
Yeah, do you have any idea how hard those are going to slam??? Straight up rediculous...
Username: Lewass
Post Number: 464
James is right, JL 1000/1 at 4 Ohms is your best bet. They will run ultra smooth and cool, with no distortion.
Unless you can find an amp that does 1200-1500 at 4 Ohms.... (Good luck! haha)
Username: Ear_splitter
Post Number: 7
Audiobahn---those amps are some of the best they hit more than they say, my friend has two RF 15" T2's and is pushin them both with a 2000 watt audiobahn amp!!!!
Username: Jl_rock
Temecula, California U.S.
Post Number: 38
are those w6's any good? i'm willing to bet they are louder than hell
Username: Loc_out
Santa Ana, Ca
Post Number: 343
Will see they are going into my Avalanche. I hope they hit hard
Username: James1115
Ct
Post Number: 5435
yes they are very good
Username: Loc_out
Santa Ana, Ca
Post Number: 344
what kind of box should i go with?
Username: James1115
Ct
Post Number: 5438
I ran my 3-10w6's sealed and they sounded AWSOME.
Username: Lewass
Post Number: 487
I got mine in a ported, but am considering sealed for when I get my next car, because I am going for sound quality. Though they do sound great ported, I can't detect any port noise at all unless it's a song with very high levels of bass, at a very low volume (like 5 to 10% of max volume).
You will need to beef up your electrical system. But if you do everything right, even a sealed box should make you feel light-headed by the end of a song! Be prepared for things in your car to stop working... like especially the backlights of your instrument cluster and climate control knobs... LOL
Username: Loc_out
Santa Ana, Ca
Post Number: 345
I'll tey that out. James what set of Components should i run?
Username: Lewass
Post Number: 492
James can you PM me the size and shape of your box for the three 10w6's sealed? That is going to be my next project.. I believe the magic number for each separate chamber's ratio of LxWxH is .8 x 1 x 1.2, respectively. How many cubes did you use for each chamber?
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 791
do not buy an audiobaun amp.
Username: Loc_out
Santa Ana, Ca
Post Number: 346
I use to own a HC2300 i believe it was okay, but i wont go back
Username: James1115
Ct
Post Number: 5440
well lewass my box is a box I bought with my w6's from JL here is a pic of it. I believe it is .75cu/ft per sub
Username: James1115
Ct
Post Number: 5441
well lewass my box is a box I bought with my w6's from JL here is a pic of it. I believe it is .75cu/ft per subjl pi small.JPG
Username: James1115
Ct
Post Number: 5442
hey Loc out how much do you want to spend on components?
Username: Loc_out
Santa Ana, Ca
Post Number: 348
I was looking into the DIAMOND D661A. Budget right now is around 200 bucks maybe 250...
Username: James1115
Ct
Post Number: 5448
do you use ebay?
Username: Loc_out
Santa Ana, Ca
Post Number: 349
Hell yeah that's how i got my 15's....
Username: Loc_out
Santa Ana, Ca
Post Number: 350
Username: Loc_out
Santa Ana, Ca
Post Number: 351
I plan on buying a Yellow top and maybe a cap. Will i have to buy a HO alt?
Username: Loc_out
Santa Ana, Ca
Post Number: 355
lil help james?
Username: James1115
Ct
Post Number: 5486
what size alt do you have in your avalanche? I am pretty sure its 135-160 right? what amp are you going to run to your mids? here is a nice set of comp's for under $200 http://cgi.ebay.com/Focal-Polyglass-165-V1-6-5-2Way-Component-Speaker-NEW_W0QQit emZ9704433059QQcategoryZ18800QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ADS-A-D-S-246ix-6-5-COMPONENT-SPEAKER-SYSTEM-SET-NEW_W0QQite mZ9705196324QQcategoryZ32819QQrdZ1QQcmdZViewItem those are nice too:-) I have the 346's and I love them.
these sound good for the price also:-) http://cgi.ebay.com/ebaymotors/JL-AUDIO-XR-650-CSi-2-Way-Component-System_W0QQcm dZViewItemQQcategoryZ38646QQitemZ8051938618QQrdZ1QQsspagenameZWDVW
Username: Loc_out
Santa Ana, Ca
Post Number: 356
I think my alt is 160 and i plan on running 1 1000\1 and a 300\4. The focal look nice the JL XR-650-CSi-2 are way off my budget.
