CDA 9855 too loud - need help
Username: Gatorman26
my Alpine 9855 is too loud. Even volume 1 is too loud to have a decent conversation in the car. Any suggestions? I have a 2001 Acura CL and was thinking maybe the factory amps have something to do with it. Thanks!
Username: Illuminator
Post Number: 2800
If you are sure there are factory amplifiers in the vehicle, then yes, that is absolutely the problem. They are designed to amplify essentially a low-powered head unit (the stock head unit), but you have certainly replaced it with something much more powerful-thus causing problems.
You'll need to get an amp bypass kit.
