How over rated is this amp?
Username: Dvo125
Post Number: 20
how over rated is this amp? Running for TYPE-R
http://www.cardomain.com/item/PHOXS2500
Username: Rovin
Trinidad & T...
Post Number: 7223
if thats a new model then hardly any1 here will know
a new type R can easily handle 600wrms - so look 4 an amp that put out that
like orion 600d or kicker 600 etc .......
Username: Nypdlapd
Post Number: 230
That one is over rated when i checked my friends at bridged it put out 457.5 watts and 115.8 in one channel!!
Username: Matt12490
Benicia, California USA
Post Number: 643
it says 500rms bridged at 13.8 volts so i dont think that amp is over rated. the over rated amps will give you numbers that can only be had at 15+ volts which no one will ever get.
