Orion HP12D4 & (Old) Punch 400.4?
Username: Fuse
Does anyone know if the old gray Punch 400.4 briged out will produce enough power to run 2 Orion HP12D4's (Dual 4ohm 500 watts RMS - 1000 Max)? If not what would you recommend? Oh, and has anyone tried the Orions?
Username: Tjmutlow
Post Number: 1779
you can not run thaqt amp bridged with the d4 sub per pair of channel, ohm load is to low or to high. you need dual 2 to use that amp
Username: Fuse
MAN!!!!!!!!! I wish someone would have posted this sooner. I just ordered the 4 ohms and customer service is already closed for the day. Are you sure about the D2's? A friend of mine had two of these with a Punch 45 pushing them in a camaro and it did fine. I am not doubting you just curious.
Thanks,
Fuse
Username: Tjmutlow
Post Number: 1781
it will play, but will clip and will evevtually burn the amp out...
Username: Fuse
I thought the 2 ohm dual voice coil would do that. Man... I guess I really don't not a thing about car systems. Are you 100% sure?
Thanks,
Craig
Username: Tjmutlow
Post Number: 1792
if you have dual 2 you wire them up to a 4ohm load then bridge.
Username: Fuse
What amp would you recommend for these subs? I am not looking to spend a lot of money. Oh, and sorry for the grammar in the previous post.
Thanks again,
Craig
Username: Tjmutlow
Post Number: 1793
what kind of money are you looking to spend...
Username: Fuse
$200 - $350
