Havoc 15"
Username: Montecarlos11
Louisville, KY USA
Post Number: 8
Would my alternator (200 amp) be able to power 2 Havoc 15"s? They are rated at 1500RMS a piece at 2ohm, i believe. I have had a couple ppl tell most likely not, some say my like will still dim. If this is true how much could i power them without diming my light too much?
Username: Mygame5982
Houston, Texas Us
Post Number: 41
It should be able to handle them, but depends on your amp. maybe a 2400 watt amp at max
Username: B101
Queen City, NC USA
Post Number: 1974
u will be just fine! if anything, u can add a yellow top battery!
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2008
Micheal...i live in KY too!! i ordered a havoc a couple weeks ago, ha ha another hick like me getting a great woofer like the havoc(hopefulyl)
Username: Andysd03
Post Number: 24
It be fine just buy a yellowtop battery and a 10 to 20 farad capacitor and ud be fine with a 3000 watt rms amp ud need to buy a battery isolator though for 2 batteries they arnt much.you can find caps at onlinecarstereo.com and good batteries at woofersetc.com. that be alot cheaper then buying a bigger alternator!
Username: Ctmike
Ct.
Post Number: 81
10 to 20 farard cap!^^^
1 farad for every 1000 watts, for ex. 2000w-2 farad cap.
and don't think having 2 batteries or caps. are a replacement for a ho alt., you'll kill you're car that way.
Username: Extremesound1
Coventry, RI United states
Post Number: 11
what the **** hell is havok never heard of them explain
Username: Baseball1187
Columbia, SC
Post Number: 636
2500-3000w RMS is A LOT. that is drawing about 180a with 2500w and 215a with 3000w RMS (14v). That leaves very little to run your car. Adding a battery will not help while the car is running, the cap won't either. It will work sure, but the voltage will drop and the headlights will still look like a disco ball. If you have the money for 2 hAvocs and that 2500w of power, do it right and invest in a bigger alternator.
I'd stick with 1 hAvoc and 1500w RMS, done properly... I would imagine it will be VERY loud.
Username: Blkwardog
Post Number: 7
u guys that hav havocs...do u think it would b betr for me to get a pair of them over a pair of JL w6v2's or an Image dynamics ID MAX or even a pair of kicker l7's?
Username: 54danny54
Post Number: 2014
i would say yes definatly(to blkwardog).
The hAvoc is a competition SPL woofer, yet it supposed to have good SQ
Username: Delsole
Post Number: 212
http://www.ascendantaudio.com/havoc_page.html
Username: Goose5714
Post Number: 392
I think he'll be fine...unless he's competing...your never gonna constatnly be drawing anywhere close to 3000 watts. If he adds a yellow top i think he would be okay. Oh and he doesn't need an isolator if he isn't gonna be running his system with the car off.
Louisville, KY USA
Post Number: 13
how much is a yellow cap and where can i find 1. also i am assuming this a high performance battery of some sort.
Username: Blkwardog
Post Number: 8
does anyone know how much longer the havoc will be on pre-order??
Username: Six
Flint, MI U.S.A.
Post Number: 449
It isn't available for preorder and hasn't been for about 3 weeks. They are just slow to update their site.
Username: Blkwardog
Post Number: 10
alrite thanx six
Username: Talon_es93
Post Number: 71
so i can't get one no more?
Username: Six
Flint, MI U.S.A.
Post Number: 452
Ive have been contacting them repeatedly since before they even came out, trying to preorder 2 of them. I just got an email from them the other day and they have none left. But Chad said I am 2nd on the list to get em once they get a few more assembled. (But that may take a while :-()
Username: 54danny54
Post Number: 2017
i ordered one a while ago and havent recived it yet...im getting aggrivated
Username: Six
Flint, MI U.S.A.
Post Number: 453
They are beginning shipping Wednesday...
Username: 54danny54
Post Number: 2018
lol i just called them and they shipped it 2day...i should get it by friday they said
Post Number: 72
i dont' wanna wait till i'm growin grey hairs... imma just go with L7s or CVRs
Username: Six
Flint, MI U.S.A.
Post Number: 454
WHAT! Those are insane alternatives to getting the hAvoc.
Username: Kingjames
OH USA
Post Number: 56
i have a question, so if i get a havoc and like a 1200-1500watt amp do i need an HO alt or would a yellow top be good?
Username: 54danny54
Post Number: 2021
u need both bryce
Username: 54danny54
Post Number: 2022
u need a HO alt
Username: Kingjames
OH USA
Post Number: 59
well would a 200a alt do it cuz i asked excessive amperage but they havent emailed me back yet so if i ran a 200 alt i that all i'd need or would
i need a yelllow top too?
Username: 54danny54
Post Number: 2023
yea 200 amps would work just fine
Username: Kingjames
OH USA
Post Number: 60
you know how much a 200amp ho alt would cost?
from excessive amperage
Columbia, SC
Post Number: 639
if i had to guess, more than 300, less than 400. I was quoted $375 for a 225a alt from them
