Help with wiring
Username: Gssc14
Hey, I just got a 311D MTX 2 Channel amp, hooking it up to a single DVC Rockford Punch sub in a bandpass box. I put both channels into the same inputs on the box, so i have 2 positive and 2 negative going into the same sub. Is that safe? Is that the best thing to do? Let me know what you think. Thanks
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2430
well, if you turned the amp on, you have a new door stop.
is the sub 4+4 ohm or 2+2 ohm DVC?
if the sub is 4+4 ohm DVC, the only way to run it with that amp (bad match) is putting one coil on each channel.
you won't be able to get full output from the amp with the load that single sub will present.
you may want to get a second matching sub.
then bridge coils on each sub in parallel, and put one sub on each channel of the stereo amp
Username: Gssc14
New door stop? It works fine.... I have been working for a week+.... How do i find out if it's 2+2 or 4+4??? It's an older sub... I don't wanna spend anymore money, is there anyway i can just hook this one up a way that it wont hurt anything?
Username: Glasswolf
Post Number: 2487
I thought you meant you ran both pos and both neg outputs of the amp to the same set of speaker terminals.
touching both together would short out the amp.
you're using one channel per coil on the sub.
that's all you're going to get out of that setup.
you should have gone with a mono amp for a single DVC sub
Username: Gssc14
I have both the positive hooked into one positive in the box, the wires are touching...I don't know what's going on in the box. Same with negative. Sorry if i sound dumb...i don't know much about this....So does this mean im running 4 ohm or 2 ohm from output on my amp???
Username: Glasswolf
Post Number: 2498
it means you're running it incorrectly and causing damage.
Username: Gssc14
Alright thanks...Should i just run one channel to the one input in my box and leave it at that? How can i run it with the one sub to not cause damage?? EEEK...i will go pull out my REM right now...lol!! CRAP! Thanks...
Username: Glasswolf
Post Number: 2512
you should get a mono amp if the box only has one input
or get a stereo amp and bridge it to one channel if its a 4 ohm box
Username: Gssc14
Why does the amp specs say like:
RCA Output
Low Pass Only
2 Ohm Load 200 w x 1
4 Ohm Load 100 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 310 w x 1
4 Ohm Load 155 w x 1
If it cant go to one channel??
Username: Gssc14
http://www.mtx.com/caraudio/products/amplifiers/thunder311D.cfm
That's the link to the specs of the amp. IM not quetioning your knowledge, just trying to get everything straight.
