Help choosing subs
Username: Algirard1
OH United States
Post Number: 146
I need help choosing a sub for my friend. He already has an amp that he wants to use. The amp he has is the hifonics bx1500d. I was wondering what subs you would suggest for a budget around $500 max? He wants sql but maybe a little more spl than sq. Thanks for any suggestions!
Username: Rovin
Trinidad & T...
Post Number: 6730
u should have said what size
but some choices
alpine type R
diamond audio D3 or D6
RE SE www.reaudio.com
kicker compvr
cerwin vega vmax......etc...
Username: Sw9152
Michigan
Post Number: 198
http://cgi.ebay.com/2-KICKER-CVX12-D4-12-SOLOBARIC-SUBS-CVX-SUBWOOFERS-NEW_W0QQi temZ5880769665QQcategoryZ39777QQrdZ1QQcmdZViewItem would be real loud in a ported box with decent sq.
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 703
2 12 inch treo TSxs...they are around 250 each.
Username: Algirard1
OH United States
Post Number: 147
I think he is looking for 12's. Thanks for the advice. I was wondering, what would you recommend, one good sub or two okay subs?
Username: Rovin
Trinidad & T...
Post Number: 6731
choices above are if u want a pair
if u want a single sub
RE SX
diamond D9
image dynamics IDmax
alpine type x
Username: Rovin
Trinidad & T...
Post Number: 6732
if u have space - do 2 12s.....
Username: Algirard1
OH United States
Post Number: 148
I was thinking of maybe the sx. Do you know how much the new sx is?
St. Louis, MO
Post Number: 705
like rovin said if he has room for 2 12s go for it. does he want it just loud (spl)...loud and sound pretty good (sql)...or just sound quality (sq)?
Username: Algirard1
OH United States
Post Number: 149
sql
Username: Algirard1
OH United States
Post Number: 150
This is going into a cavalier so there isn't a lot of room but there is enough. Thanks for all of the help!
Username: Algirard1
OH United States
Post Number: 151
I think I am going to tell my friend to get the two se's. I have heard so many good things about Resonant Engineering. I was wondering if anyone had the updated price list. I remember seeing a price list for last years prices. Thanks for the help.
Username: Rovin
Trinidad & T...
Post Number: 6735
2 12s IDmax ported.....
Username: Algirard1
OH United States
Post Number: 153
Thanks for all of the help! You guys are great!
Username: Shman
Michigan United States
Post Number: 23
if you still havent gotten any subs, you should look at the 12" ascendant audio arsenals
$220 each
