Quick Sub/Amp Question???
Jimmy Dean
I just bought 2 Kicker CVR 15 inch subs and a JL Audio 1000.1 amp to power both 15's. My question is how do I wire a mono amp to both subs? And will I get 500 watts on each sub? Thanks in advance.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2525
yes 500 to each, and wire both straight to the amp in parallel
what he means by parrel is instead of running the subs to the box and then to the amp you run the subs to each other and then to your amp. and yes 500 watts
Username: Glasswolf
Post Number: 2632
no
by parallel (not wtf-ever parrel is) I mean wire both subs straight to the amplifier.
stop trying to re-explain what I already told him, and screwing things up. thank you.
