HELP
Username: Johnz905
Kelowna, Bc Canada
I just put my subs and amp in and they work GREAT!! but they only work on the radio :-( i dont understand why i have a alpine cdm-7854 deck and the cds will play but the amp doesnt turn on but when it switches over to radio it turns on. i bridged the power wire and the remote lead and it works? please help
Username: Clacla100
Tallahassee, Fl US
Post Number: 104
you hooked up the remote wire to the antenna wire. Just switch it around with the right wire. i dont remember what its called cause im tired as crap. I believe its blue with white but im not sure. Also dont put your remote on your constant cause it will drain your battery.
Username: Johnz905
Kelowna, Bc Canada
thank you very much.. and im a noob at this stuff and what do u mean by constant?
Username: Ton
Post Number: 16
check this out. http://www.bcae1.com/asystems.htm
