Rovin or sum1......
Username: Thomas_g
NM
Post Number: 140
Ok rovin you know how like now i just have a 560 watt rms(brided) PA amp? My kicker 05cvr122 should be delivered in a couple of days. Would i be able to run it with out blowing it cuz its rated at 400watts rms but i hear PA amps are overrated. Would it sound good later on in the future if i just got that same amp and another cvr and bridged that one to instead of buying 1 better amp since i already have an amp? would it sound pretty loud?
Username: Rovin
Trinidad & T...
Post Number: 6629
Well imo - u should be fine cause the amp is overrated & most subs r underrated
i know $ is tight with u so i'd say use that amp & sub 4 now & later on buy a better amp & another of the same sub ......
Username: Thomas_g
NM
Post Number: 141
kool thanx again Rovin...
