Need help knowing wich alarm to buy
Username: Gage
Post Number: 68
can anyone suggest a good car alarm for me
Username: Teddy21
Ann Arbor, MI USA
Post Number: 40
the Viper 791XV is a great alarm, im about to get one off of ebay its about 200 dollars. Check it out at www.dei.com
It is a 2 way alarm that will tell you if someone is breaking in your car and you can start the thing from a half mile away, which really helps when its freezing out and you dont want to sit in a cold car for 5 minutes waiting for the heat to kick in.
I have an Autopage alarm like it but i would go with the Viper because of the features on it and its DEI, they make some very good car products (PPI, Orion, Viper, ect)......Upload
Username: Shepyjay
Ont Canada
Post Number: 98
excellent alarm made by dei and the clifford matrix rs3.5 is basically the same unit
