Help with sound system
Username: Xdream
Sherman oaks, Ca
Post Number: 38
hi i wanna change my head unit so that i can hear mp3 disks, the problem is that i have the cd decks gm and chryslers have...
aNd they are the big ones that look twice the size of normal ones, basically the only ones that i found that are made for my type of car are pioneers DEH-P47DH.
the thing is that they are like $400 AND dont look that good. is there any other brand that make cd players that im looking for, and have mp3?
also should i just get a normal slim cd player and have all this extra space around it? also is there a special plastic plate to transform gm size radios to the small normal civic type radios?
Username: Redliner
Wilmington, Ma
Post Number: 963
just get a trim kit
Username: Fiber
Post Number: 19
Go to wallmart and get a kit, $12
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6026
If u have a Ford Tarus or Mercury Sable, the kit is around $60
Username: Blainew
Post Number: 1048
get a pioneer head unit, one of the slim ones
they have kits to make them fit and look good....i had one big cd player and got a slim pioneer one...most people need a kit to take up the extra space.
