2nd Amp
Username: Fordeh
i am wondering if any1 can tellme how2 connect a second amp up. i have got a 2 channel 1 in now runnin my sub. how do you all da power cords 4 da second 1 ??? dis amp is 2 run my speakers.
Username: Tjmutlow
Post Number: 1279
use a distribution block and use rcas from behind the radio for the other amp
Username: Phuktupbasshead
Phoenix, Arizona United State...
Post Number: 465
But what about the fuse that goes near the battery????
Here's an example:
If i have a 900 watt amp (and am using a 100amp fuse near the battery)... then if I use a distribution block, won't I need a higher amp fuse??? I'll need to add the the amp rating of both amplifiers??? (3 30amp fuses on one amp and 2 25amp fuses on the other = total of 140amp fuse near the battery. CORRECT or INCORRECT?)
What if i just hooked up the 2nd amp and DID NOT change the fuse near my battery??? Problems?
Username: Tjmutlow
Post Number: 1632
that is enough
