Help with phoenix didital amp
Username: Bigherm78
Monmouth, Or Usa
Post Number: 25
i need help my amp worked last night and now it wont turn on it is on the protected state and wont change i changes the wires and i cant figure it out i also changes the fuses too but it didnt work can anyone help me out
Username: Tjmutlow
Post Number: 1612
unhook speaker leads, if it still does it then most likely the amp has gone bad.
Username: Bigherm78
Monmouth, Or Usa
Post Number: 26
on the amp, my amp is only like 2 months old so i have no clue y it would be bad and it worked last night and when i started my car it didnt turn on
Username: Safe_cracker
Chicago, IL US
Post Number: 380
That amp makes a Pyramid look like a Zapco, lol. Ditch it..Polo..
Username: Fandim
Reno, Nevada United State...
Post Number: 803
It could be a bad grounding point..you switched what wires exactly?
Also, make sure there's no frayed wires at the connection point, with this, it's common that they touch each other (mainly ground with remote or ground and power, etc.) And this can be bad. Or even your power to the chassis of the amp, if the ground is touching, too, etc.
Seth
