Spl and sq
Username: Logan__tille
Post Number: 20
is there a way i could build a box that has sq and spl. like could i build a ported box, and make a baffle to cover up the port?
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 2223
Yes, but you don't need to seal your box to achieve SQL.
Just build a ported box according to the sub.
http://diyaudiocorner.tripod.com/dilemma.htm
I think mtx had some silly sealed/ported box that supposedly worked. But I wouldn't believe that any farther than I could kick it.
