Amp won't turn on!!
Username: Nypdlapd
Post Number: 18
I finished installing my amp and it would not turn on!.. How can i no if my amp it blown. I had all the wires in the right wires!! if i open the amp how can i tell if the amp is blown..
Username: B101
Queen City, NC USA
Post Number: 1505
did u check all fuses first? on amp and on wire?
did u recheck your ground cable?
next step would be to start testing each wire to the back of the amplifier...
Username: Rovin
Trinidad & T...
Post Number: 6202
most importantly is the REMOTE wire hooked up !? .......
Username: Nypdlapd
Post Number: 19
There was no fuse in the amp
Thanks
Username: Redliner
Wilmington, Ma
Post Number: 847
ya im with rovin on the remote wire 20 bucks rovin says ur right thats what i was gonna put hbut then i saw ur post u ruin all my fun lol
Username: B101
Queen City, NC USA
Post Number: 1512
"next step would be to start testing each wire to the back of the amplifier..."
yea, remote, power, ground....
Username: Thomas_g
NM
Post Number: 97
Ya dont know much yet but i finally knew an answer to a ?
