Need help on hooking up my system
i got a sony xplod amp xm-2200gtx and 12" jensen bandpass subs and i got every thing hooked up but nothing happens the green light on the amp turns on i tryed hookin up a old sub that i know workes and still nothing happen anyone know anything bout this
Username: Goose5714
Post Number: 304
sell them??? i don't know to get the best bang for your buck outta them i would plug each into a 110v wall socket thats probabl the best use for them, or better yet both into the wall socket while still in the box.
No but seriously, did you hook up power, ground, speaker wire, and do you know the ohm load you are presention your amp???
Username: Belac_choj
I have a question,
I have 2 Power Acoustik LT1440-2 two-channel amps and 2 SPL CAL-12 subs. I want to Bridge them and hook them up to my Dual Head Unit, which only has two RCA outputs. I want to go one amp per sub to get the most wattage possible. But I'm not sure how. Could someone tell me how?
