Little help please
Username: Pdivvy5
New Port Richey, FL United States
Post Number: 91
Hey, i was wondering what a good quality amp would be to power my pair of Alpine Type R 10's. I have around $250 to spend, and i dont have a brand preference. I just want a good reliable amp. Thanks.
Username: Goose5714
Post Number: 274
ummmm orion 1200d? maybe a little to much power...probably want about 1000 watts right??? What coil config...thats gonna make a difference....
Username: Pdivvy5
Post Number: 92
Well here are the subs http://www.crutchfield.com/S-BC1ERlcsgN2/cgi-bin/ProdView.asp?search=r+10&i=500S WR1042 they are 10" 4-ohm subwoofer with dual 4-ohm voice coils.
Username: Tjmutlow
Post Number: 1521
maybe the 600d or a JL 500/1
Username: Goose5714
Post Number: 276
I'd get more power than that ^^^ since they are dual 4 you can wire em up to a 1ohm load so...a 1200d orion, or viper, or basically anything that is 1 ohm stable and pushes 1000rms would push them pretty good..
