So many batteries, which one?
Username: Mystre
Pemberville, Ohio USA
Post Number: 40
OK, I just went to look into a new battery and I found out that there are several different models. Which one would I want to get?
Car: 2002 Dodge Stratus SE 4 cylinder
System: 1 JL Audio 500/1 pushing 2 JL (alternative) 12W6s.
Battery: Enersys, Optima, Orbital, or Odyssey?
Username: Bkoz
Post Number: 25
Optima yellow top
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1152
i'd go with an Optima Yellow top.
but i read on here someone saying that Odyssey makes stinger's batteries.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11215
I'd go redtop for a starter battery.
stinger or kinetik for audio batteries on an isolator.
Username: Mystre
Post Number: 41
GlassWolf, your opinion is always appreciated. I have been to your website and I trust just about anything that you say (write). Ok, redtop, but which model? Best for the least amount, if possible. Budget? $150 or less (obviously).
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11224
their website should help you pick the right one for your car.
www.optimabatteries.com
Username: B101
Queen City, NC USA
Post Number: 1408
"Battery: Enersys, Optima, Orbital, or Odyssey? "
Optima are great, the yellows are best for audio!
I would forget those get a Kinetic battery!
"but i read on here someone saying that Odyssey makes stinger's batteries."
Brandon they are the same from my knowledge, just peal the sticker off the Odyssey.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11283
Kinetik if it's on an isolator, but redtop for a starter battery.
the redtops recharge the fastest of the red, blue, and yellow, and have the highest CCA ratings.
