Amp for L7's
Username: Steven132221
Post Number: 14
i have two 06 model 15" L7's which are 1000 rms and 2000 max, and i was wondering what amp or amps sould i go with. my budget is around 600 dollars but i could go a bit higher if i need to, like if i go with two amps.
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 618
are the subs dual 2 or dual 4ohm?
Post Number: 16
2 ohm
Post Number: 22
should i go with two amps or one amp? and which amp/amps would you go with?
St. Louis, MO
Post Number: 620
2 orion 1200ds would be nice.
St. Louis, MO
Post Number: 622
actually for the price this is at u might wanna go with it and wire them both up to 2ohm.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2666
the free shipping helps alot
Post Number: 27
i am confused on the wattage. if i got that kicker 2500 that would put 1250 watts to each L7 right? that wouldnt be close to maxing the L7's out at 2000 watts a piece right? or wrong?
Post Number: 29
i want 2000 watts going to each sub, how would i do that?
St. Louis, MO
Post Number: 624
you want to go with the L7s rms which is 1000watts. i would not give an L7 2000watts for an everyday ride, maybe for competitions. also when running 4000 total watts rms you are going to get a new alternatior, battery, and upgrade your wires. its really not worth it in my opinion.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 651
i blew my 15" l7's with my kx2500. The birth sheet said 2885 watts. I turned the bass boost all the way up though. If you setup right then you will be safe.
Username: Shortyman513
Post Number: 15
i also have(2) 06 model 15" kicker L7's and i have each one hooked up to its own Kenwood 1700 watt amp and have the output level and bass boost level turned up only like 3/4 of the way and these subs rattle everything imaginable in my accord... my damn front bumper rattles, lol... i got BOTH of these amps for $360 total off of ebay. u should go check them out... they goy some good stuff for good prices... l8r
Username: Mangle
Lynchburg, VA USA
Post Number: 9
I agree the Kenwood 9152 will do the sub justice buy two brand new off ebay 150.00 each 900w rms 1800 max clean and very responsive amp, I have one 9152 hooked to four MB quart 10" subs and believe it or not it slams hard very hard.
Post Number: 43
thanks guys! should get two of the kenwoods or get one/two of the following:
viper 2500d
orion 2400d (west coast customs amp)
directed 2400d
St. Louis, MO
Post Number: 625
viper 2500d
Post Number: 48
could i hook up one viper 2500d up to one new 15" L7 and just turn the bass down a little bit so i dont blow the sub? i wanna be loud as hell to be able to compete with people as in competitons! thanks for the help so far!
St. Louis, MO
Post Number: 632
you "could" but thats still a ton of power for one 15. you can run 2 with that amp just fine.
Post Number: 52
icic
