Amp problems
Username: The_dave
Post Number: 14
i was usin a Bass test tones cd on my sub to see what it sounded like and after a few tracks the whole system shut of. Amp power light went of. I took out the fuse from the amp which was a 15 and replaced it with a 20. It works now, though is there likely to be any lasting damage?
thyo
bump
bump
Username: James1115
Ct
Post Number: 5089
what amp is it? are you sure a 15 was supposed to be in there?
JohnnyRichter
ill be driving around in my car and all of a sudden my amp stops working and the power light goes out and the fuses r good...what do u think the problem is?
JohnnyRichter
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1272
how big is your amp,
JohnnyRichter
300 watt
Username: Redliner
Wilmington, Ma
Post Number: 751
you prob have a lose connection check them all especially the power wire that is connected to the battery
JohnnyRichter
i did that already..like it will work one minute then it jus quits..do u think my amp is bad?
JohnnyRichter
Username: The_dave
Scotland
Post Number: 15
This is my amp
http://caraudiosecurity.com/shop/product/products_id/2910.html
This is my sub
http://caraudiosecurity.com/shop/product/products_id/4027.html
I presume that fuse was supposed to be in it, guessin it came with that fuse. though one of my friends set it al up for me so he might have put the fuse in it himself
paul sety
bump
Username: James1115
Ct
Post Number: 5125
well from its power ratings it make sense that a 20 should be in there but I am not sure of JBL's actual ratings. what fuse do you have in-line near your nattery?
Username: The_dave
Scotland
Post Number: 16
i have a 30 in there.
Matt Davies
bump
Username: The_dave
Scotland
Post Number: 19
bump
Username: Mkars111
Florida USA
The amp should have a 30 amp fuse.
bump
