How can i tell if my sub is blowin
oookke
i got 2 12 and one of them started to make a cracling noise but they where fine when i turnd my car off when i turend it bak on one was making that noise does ne one know why it is doing this or tell me how i can tell if its blowin
Username: Lexuscoop
Post Number: 938
maybe the voice coild is scratching. im pretty sure you can tell your sub is blown if you look at it
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 671
loose tinsel lead?
Username: Ironslave
Post Number: 158
yea i think lucas would be right.... take it out and smell it i would bet that the voice coil is overheating... melting the glue, making the voice coil unwind and destroying all that is holy... .. you might be over driving your sub... what kinda sub do you have?
Username: Terry6405
Sullivan, IN US
Post Number: 444
umm.... it doesnt work anymore
Username: Greeney1888
Maple Grove, MN United States
Post Number: 167
take a AA battery and connect your +'s and -'s and your sub should move in and out if its not blown
Username: Shepyjay
Ont Canada
Post Number: 8
or maybe check it with a multi meter on ohms setting of course also check the tinsel leads
Username: 420pimp2
Post Number: 557
same thing happened to my rf punch sub one has that crackling sound but still gets really loud
