Looking for a good sub complimentary
Username: Laethageal
Hello every body. I've been looking for different sub for sometimes now. I want to put a 12" in the back of my contour 98, something that'll drop lower that those 40hz we see in cheap subs. I put a Pionner DEH-P8MP as head unit, going to an AudioBahn amp, 4 chan delivering 800w, (I don't remember the unit code). It goes to 4 Infinity Kappa 62.3i.
I've had enough middle and high frequencies with those, but don't have anything lower 80hz. I've looked at the JL 12w7 or 13w7, also looked at the JBL W12gti. I'm open to other suggestion and to which amp you'd use. I want good SQ first, but without having poor SPL. Thanks for your help
Username: Rovin
Trinidad & T...
Post Number: 5804
http://ascendantaudio.com/
Username: Jemone
Stone Mountain, Georgia United States
Post Number: 83
Rovin you plug ascendant audio when ever you can. Do you work for them or are they really good?!!!lol
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1795
ha ha well they are pretty dayum good man... Also they like drop REALLY LOW compared to other subs
also a W7 be nice
Thanks for the info. Btw, any of you heard Memphis subs ? Some local dealer breath and live for those, but I'd like outside opinion on that brand.
Here's the info on those memphis sub:
http://memphiscaraudio.com/LiveImages/114/4/DocumentURL.pdf
Username: Demon_pride
Crowder, Oklahoma USA
Post Number: 61
Uhm, REaudio.com? If you have the money for a W7 then you have the money for a XXX or two. They own. I don't think you want SX because they are a little more SPL oriented, but retain some SQ. SE's are alot cheaper than the W7s, but would take a couple of them to get as loud.
Username: Pelona
Post Number: 765
are there any other subs that can drop lower than ascendant audio's subs?
Username: Alteraudiousa
Concord
Post Number: 331
Ascendant's don't drop lower than most other good subs. All depends on box. W7 is good but would overdo your inside speakers. You have audiobhn and W7 in same sentence in same car...something is wrong.
