SiX and Baseball1187
Username: Anthony1
Post Number: 23
or anyone else who has an opinion on this subject but it seems like you all know about comparing RE and Ascendant subs so, in your opinion would an Arsenal 15 given a solid 500 watts @ 4 ohms be louder and sound better than a SX15 given 700 @ 2 ohms? i'm not trying to underpower them i'm just stuck with this MRD-M1005.
thanks in advance
Username: Anthony1
Post Number: 25
bump
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1853
from what i hear...they SX gets louder but the ars es gets lower and clearer
Username: Baseball1187
Columbia, SC
Post Number: 603
you're not gonna be able to give an SX anything at 2ohms unless you get dual 4 ohm coils (custom) they come standard with dual 2.
Going off of speculation, i would say the Arsenal will be louder and sound better. The ava and SX were neck and neck in output, and the arsenal is supposed to be louder than the ava, SiX says this is true as well... I say arsenal all the way, but that's just me
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2144
that alpine amp is 1 ohm stable? give the arsenal all 1KW! just be careful. but i know it can take it!
Username: Hootz
Saskatoon, Saskatchewan Canada
Post Number: 117
"you're not gonna be able to give an SX anything at 2ohms unless you get dual 4 ohm coils (custom) they come standard with dual 2."
Not sure where Anthony got his specs from but the mrd-m1005 is 1000w at 2ohm and 700w at 4ohm, so he'd actually get 700 with the sx.
Username: Six
Flint, MI U.S.A.
Post Number: 418
Also, all Arsenals have dual 4 ohm config so it'd recieve the same power...
Username: Anthony1
Post Number: 26
I got those spec off of alpine's website http://www.alpine-usa.com/en/products/product.php?model=MRD-M1005
I was going with the power ratings at 12 volts
Post Number: 2148
oh yeah, the arsenals are D4 arent they. wire that arsenal up at 2 ohms and you'll get ur 700 at 12V and 1000 at 14.4V and call it a day.
Username: __nick__
Post Number: 23
Hey I have two Alpine Type R 12"s that are 4 ohms and Dual Voice Coil. They are 500 watts rms and 1500 watts peak each. Will this amp overpower them or will it match up well? Hifonics BXi 1606D, It runs 1600 watts which would mean I'd be running 800 watts to each sub, would that blow them out or is it a nice match, please answer back soon,
Thanks...
Post Number: 2150
as long as that amp is one ohm stable, and i think it is, they will go fine with that amp. the subs will actually only see about 700-750 a piece and if done right (setting gains and such) you will be fine, but if you turn ur gains up to high or use bass boost and clip the signal then you will blow them.
Username: __nick__
Post Number: 25
thanks, would bestbuy be able to install them right so they dont blow or do i need to take them to a specialist
Username: 54danny54
Post Number: 1862
no best buy...look for woofer wiring wizards. i dont know the configs of the coil so i couldnt show u a direct link
Username: Six
Flint, MI U.S.A.
Post Number: 419
Anthony I have 2 arsenals for sale.. $250 + ship each or $500 shipped for both... If your interested in 1 that'd be great because I have someone else wanting one as well... my AIM is: SiXStatiC Hotmail: skazi_six@
