Out Spare Tire In SQ Subwoofer
Username: Azngotskills
Sugar Land, TX USA
I was wondering if you guys could help me...I used to have two 12 in a box in my 2000 celica which was too loud and took up too much space. I want to remove my spare tire and put a 10 or 12 in there instead.
I wanted see if you guys could give some suggestions for a 10 or 12 SQ sub that will work in the spare tire well??? Looking to spend around $100-200 and i will buy a new amp soon.
Thanks in advance
Username: Langless28
Post Number: 326
you would still have to build a box in the well. specially if you want it to sound good. some dimensions would help too
Username: Terry6405
Sullivan, IN US
Post Number: 406
ill bet as soon as you get that box in you have a blowout, about 3 days ofter i put my difficult-to-fit-in-trunk- box in, guess what.... blowout
Sugar Land, TX USA
So are you guys saying that I just cant put this sub in the tire well if I deaden it and make a baffle? I thought that I dont actually have to make a box to specs if I was SQ.
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1857
guys...give him woofer suggestions.
look into crystal www.realmofexcursion.com and click store
the crystal comp will get loud and sound very clean
look into eclipse titaniums www.woofersetc.com
ascendant audio assasin www.ascendantaudio.com
RE SE www.reaudio.com
Username: 54danny54
Post Number: 1859
i keep forgetting image dynamics
www.woofersetc.com ha good prices. get an ID Max and it will get plenty loud also
Sugar Land, TX USA
any more opinions around 100-200
Username: Terry6405
Sullivan, IN US
Post Number: 435
if your gonna put it in the well, i would make a fiberglass elcosure to fit right in there, expensive but worth it
a perfect 12.1 or two would be great
Sugar Land, TX USA
Post Number: 7
yea thats what I was thinking
