Helllllppppp !!!! ascendant audio vs re audio
Username: Extrmndor3
Chicago, Ill Us
Post Number: 10
hey wats up can you tell me wich be louder i mean the most db's as possibles with 300 watts each,
2 ascendant audio assasins 12 inch,
2 re aduio se 12 inch
1 re audio 15 se or sx
1 ascendant audio arsenal 15
each subwoofer at around 300watts at 2 ohm with a box with 5 cubic ft per chamber ported thanks
Username: Langless28
Post Number: 328
you would be extremely underpowering any of those re subs with 300 watts max. specially at 2 ohms
Chicago, Ill Us
Post Number: 11
no i mean rms
Chicago, Ill Us
Post Number: 12
and for now im planning to buy the precision power 1000.1 but for now i have two 800 watts maxx amps each is rated at 400 rms at 2 ohms
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 617
you can run 2 SEs with 400rms each. its underpowering them quite a bit but it will work.
Chicago, Ill Us
Post Number: 13
so 2 se's will be better than 2 ascendant audio assasins, 1 15 inch sx's and 1 15 inch arsenal
and in 4 weeks i'll be upgrading the amp to a precicion power 100.1 or hifonics bx2005dx
Username: Rovin
Trinidad & T...
Post Number: 5933
if were me i'd buy 1 15" AA HAVOC then worry about what amp 2 buy - thats a super deal AA has going on now .......
http://ascendantaudio.com/havoc_page.html
Username: Six
Flint, MI U.S.A.
Post Number: 421
^^^ Yep. Sure is a great deal... I'm gonna have 2 15" havocs soon! WooT!
Chicago, Ill Us
Post Number: 14
so 1 havoc running at 1000 watts rms will be louder than any of those set ups with the same box and can you suggest a cheap set up but louder and cleaner
Username: Rovin
Trinidad & T...
Post Number: 5937
That ^^^ would be a badass system SIX !
even though i'm happy with my 2 12s R - i'm very tempted by this special offer ......Upload
Username: Rovin
Trinidad & T...
Post Number: 5938
Er - a havoc is rated @ 1500 wrms not 1000wrms - u could power it with that Hif 2005D is $ tight ....
