SERIOUESLY HELP!
Username: Lexuscoop
Post Number: 913
ok my buddy needs a GOOD amp... and wiring kit BUT only has 150 for both... can ANYONE help me... please...
Username: Greeney1888
Maple Grove, MN United States
Post Number: 150
highly doubt he will be able to pull it off sorry man
RMS?
Username: Lexuscoop
Post Number: 915
1100 each sub... i might pitch in 100 so probably 250 for amp and kit 2 subs 1100 rms each
Post Number: 151
not possible, your wires are probably gonna run you at least 100.00 and theres not amp out there thats "good" that will give u the true 1100RMS in the 150.00 range
Username: Lexuscoop
Post Number: 917
it doesn't have to fully power them though. i mean he can run about 1k RMS so 500 to each with in the 150-250 rang right?
Post Number: 152
check hifonics amps
Username: Lexuscoop
Post Number: 921
i can't find an amp thats 1 ohm stable:-(
Username: Lexuscoop
Post Number: 922
http://www.millionbuy.com/splz1x3000d.html
he's willing to save for a little while longer, would this amp be good for 2 1100RMS subs? DVC 4ohm
Username: Rovin
Trinidad & T...
Post Number: 5886
check out http://www.ikesound.com - they have some good econo stuff there ......
Username: __nick__
Post Number: 24
Hey I have two Alpine Type R 12"s that are 4 ohms and Dual Voice Coil. They are 500 watts rms and 1500 watts peak each. Will this amp overpower them or will it match up well? Hifonics BXi 1606D, It runs 1600 watts which would mean I'd be running 800 watts to each sub, would that blow them out or is it a nice match, please answer back soon,
Thanks...
Username: Bkoz
Post Number: 23
1100rms what do u want to be deaf???
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1860
lanzar vibe amps?
Username: __nick__
Post Number: 26
Thanks...
Username: 54danny54
Post Number: 1863
nick...
option one
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Terry6405
Sullivan, IN US
Post Number: 408
that should be fine nick, you might be a little careful thou, set your gain just a smige conservitively and it shoud be a good match
here comes the hifonics-is-overrated stampede....
Username: Rovin
Trinidad & T...
Post Number: 5894
Nick has posted his ? all over town
https://www.ecoustics.com/electronics/forum/car-audio/202764.html
Username: Lexuscoop
Post Number: 924
Rovin would this bee a good amp for the subs?
http://www.ikesound.com/product-product_id/3775
Username: 54danny54
Post Number: 1872
MA amps are pretty good IMO...tell him to get it.
does ur friends have audiobahns?
