Regluing a surround to the cone
Username: Ironslave
Post Number: 31
i was wondering if aqnyone here has any input on regluing a surround to the cone?
i bought a new box for my subs and i pulled the surround loose on one of the subs...
it's an in finifty 1230... i love thiese subs and i would really like to salvage it... i tried super glue and J.B. Weld to no avail... i just have to reglue it to the cone....
Yeah shure try it and let us know how it works !!
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2252
so the rubber (or foam) surround lifted away from the metel frame of the sub?
use 2-part epoxy glue if that is what happend.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 942
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=340-076
Username: Ironslave
Post Number: 32
it came off at the cone.. cone is plastickish.... i was thinking a hot glue gun but already know the outcome of that O.0
Username: Ironslave
Post Number: 33
your link didnt work sorry
Username: Rzarector
Post Number: 945
superglue and jb weld are brittle so they wont work.. try silicone( ONLY if its rubber surround) hot glue wont bond well enough to hold
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 120
Try some of that new Gorilla glue stuff, it's suppose to be the strongest stuff right now.. a little bottle it like $7..
