D910d4 vs. sw9102
Username: Moparx12
how does the diamond compare to the eclipse? i have a 600 wrms audiobahn amp and i am not happy with the audiobahn sub i got with it. i want great SQ but i want it too be really hard hitting as well.i would rather not invest in a bigger amp if the diamond is comparable to the eclipse. is the diamond underrated like the eclipse?
Username: James1115
Ct
Post Number: 5211
if you want SQ I would go with the eclipse over the d9. what are the specs on your amp?
Username: Moparx12
the amp is the audiobahn a12005dt, it puts out 600 wrms @ 2 ohms, 375 @ 4 ohms,
i heard the eclipse needed alot more power than this amp and i would rather not upgrade my amp right now.
diamond audio doesnt compare to eclipse in SQ?
btw, what is SQL?
Username: James1115
Ct
Post Number: 5214
SQL is a mix between SQ and SPL, a daily driver sub. well given the specs on your amp you really dont have much of a choice. I would get the d9 dual 4ohm and run it at 2ohms.
Username: Moparx12
Post Number: 7
is 250 plus shipping a good price for the d9?
oh and what is an adequate sealed enclosure volume?
thanks
Username: Moparx12
Post Number: 10
oh,
and do you think the diamond will signifigantly out perform the audiobahn aw1000n (600 wrms dual 4) that i have now in a .77 cubic foot sealed enclosure?
Username: James1115
Ct
Post Number: 5218
with your power 1.25 sealed or 1.25 ported tuned to 33hz
Username: Moparx12
Post Number: 11
thanks
will it be a big jump up from the audiobahn sub?
Username: James1115
Ct
Post Number: 5221
yes
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2074
why dont you get the D6? arent they 600w rms?
Username: Moparx12
Post Number: 12
yes the 12" d6 is but im referring to the 10" d9
Username: Vinnyqh
Portland, OR
Post Number: 184
diamond all the way, eclispe is nice, but the diamond is better!! d9 kicks the d6 butt any day of hte week!!!
Username: Kd7nfr
Montpelier, ID United States
Post Number: 1521
LOL! There's a dealership up here that is all Diamond. And my Eclipse Ti's were louder and sounded better than the D9s and the TDX's, no matter how hard that shop tried...
Just my .02.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5832
Yeah, eclipse is better then diamond overall, the best thing about diamond are there amps
Subs=Eclipse
Amps=Tie
HU=Eclipse.lol
