WHATS THE BEST??????
Username: Manwithneeds
ATLANTA, GA
Post Number: 7
WHAT IS THE BEST SUBS TO BUY ..I WANT TO GET TWO 12" SUBS...AND MY BUDGET IS $600 FOR THE SUBS. ANY ONPINIONS ON WHAT I SHOULD GET...????????????
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1344
2 Ascendant Audio Assassins or RE Audio SE's.
ATLANTA, GA
Post Number: 8
THATS KEWL..CAN U SUPPLY ME A SITE...SO I CAN CHECK THEM OUT...GOT NOTHING IN SEARCH ENGINE.
Username: Goatin
U.S.A
Post Number: 351
you could get 4 15" Kicker CVR15 's for that budget www.ebay.com Key Word CRV15
ATLANTA, GA
Post Number: 9
I WANT LIKE COMPETITION SUBS....SO I CAN BE HEARD...THOSE CVRS ONLY HITTN BOUT 450 RMS..EACH...KINDA LOOKN FOR MORE POWER..AND A BETTER BRAND... ITS ALL GOOD...APPRECIATE IT ANYWAY THO.
Username: Goatin
U.S.A
Post Number: 353
Yeah kicker Comp VR..
ATLANTA, GA
Post Number: 10
CLEARLY NOT BEING A DICK..BUT I DONT WANT KICKER...THAT SUB ONLY HITS 200RMS..SEEMS U R GOING WRONG DIRECTION...AND THE SUB ONLY WIEGHS 8 LBS. THATS WEAK...I HAD SOME AUDIOBAHNS HIT 1000RMS AND WIEGHED 30LBS. AND THEY COST BOUT $149.99 EACH. I WANT SOMETHING MORE...
Username: Safe_cracker
Chicago, IL US
Post Number: 237
2 RE SX 15s in a 8cf ported enclosure should throw you back. Polo..
http://www.reaudio.com/html/
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1993
or 2 ascendant audio Havocs
www.ascendantaudio.com
Username: Pelona
Post Number: 673
audiobahn sucks.
try to get some a bunch of kicker l7s. theyre really cheap for how loud they get. bad sq though.
Wellsburg, WV USA
Post Number: 1350
Trevor, he wants two 12" subs. The hAvocs don't come in 12"...And they're $425 a pop. That's KIND of why I suggested the Arsenals lol.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5764
2 12" Orion H2's, not the best sounding, but will kill the audioburns
Post Number: 1997
oops didnt see about the 12s. and tyler you said assasin by the way.
http://cgi.ebay.com/ECLIPSE-SW9122-12-DVC-SUBWOOFER-1500-WATTS-TITANIUM-05_W0QQi temZ5866036012QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Greeney1888
Maple Grove, MN United States
Post Number: 114
what polo said, "2 RE SX 15s in a 8cf ported enclosure should throw you back."
^^^i think marshall white hit 148db with his 1 15sx
Username: Terry6405
Sullivan, IN US
Post Number: 338
R U figuring in the cost for an amp, or do you have one? what about an alternater? maby you should spread out your 600$ to be sure what you gat is sutable for you
Username: Alteraudiousa
Concord
Post Number: 291
one Stereo Integrity Mag 15 and call it a day. No need for two when one will do.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 1494
If you have plenty of mone for an amp, go with RE SX. If you're limited on $ for an amp, go with some Eclipse Ti's. The RE SXs are louder, but require more power... But the Ti has a little better SQ at the same time.
