Eq wat is it
ok i keep hearin about eq wat the hell is it.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 826
Equalizer.
http://cgi.ebay.com/audiocontrol-EQ-S-pre-amp-Equalizer-like-new_W0QQitemZ586491 0130QQcategoryZ14931QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ALPINE-Model-3331-11-BAND-GRAPHIC-EQ-PRE-AMP-NR_W0QQitemZ586 9401620QQcategoryZ14931QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/MA-Mobile-7-Band-Audio-Equalizer-Subwoofer-Crossover-NR_W0QQ itemZ5869229801QQcategoryZ79841QQrdZ1QQcmdZViewItem
my bad i ment to put sq
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1906
sound quality
SQ-sound quality
SPL-sound pressure level
anything else lol
Orangevale, Ca. USA
Post Number: 828
Sound quality;
SPL
yea wat 15s have good sq
Post Number: 1909
lots of them. whats your budget? and do you already have an amp? if not whats your budget on the amp. and are you going to get a HO alternator?
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1698
for sq id go more for a 12''....alpine type x , image dynamics idmax , jl audio w6v2
ok all my shits in a house i already have 2 12s 2 15 audibhans that i dont like really they get destorted 2 easy. ad i have a rockford amp. do u wanna see picks im only 17 i think i did damb good.
Post Number: 1705
thats very common for 16 and 17 year olds to get audiobahn because they're so shiny , chromed and flamed up and most of them love them just because they get loud and they care nothing about sq
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1058
yeah, you won't get very good SQ from any of thoes Audiobahn's. try to sell them off to another kid and look into getting one of the subs Casey mentioned above, Alpine Type X, IDMAX or JL W6v2.
yea well i actuly didnt buy the audiobuhns i bought the orions12s kicker6x9s and pionear6x9s.
