Archive through February 21, 2006
Closed: New threads not accepted on this page
  Thread Last Poster Posts Last Post
My 15'' re sx boxresx1
Replacing batteryMark S8
Need help on deminsions for a box!!Napoleon DY-NO-MITE2
Whats the differenceMitchell Stone3
Off Topic, but pleaz HELP!!Andre Jamison8
Enclosure for 2 12 JLW7KLC14
Sellin Off some stuff to pay for my bail lolYukhui cant sign in5
Difference in spl and sq in different types of carucfsaxman2
Which would be louder?Trevor Eaton5
ClarityNOL1M1TSOLD1ER3
Tang BandMO7
Dog or systemKLC26
Loudest 15"onus2u10
Are there any powerful subs that work well at low levels?Night Mirage5
How 2 install system in mercedes E classNight Mirage4
Stock system in 06 mustang gts...james3
What kind of port is better?Trevor Eaton6
Best subsTrevor Eaton7
Plz help..Polo5
Re sx 15 hole cut outTerry64054
Mtx ThunderFoam Anonymous9
Cvx VS L7 for RapNapoleon DY-NO-MITE16
Off topic: BMW X5B39
Box for h2 15Wahl3
Need a good amp for 2 10` alpine SWR-1022DGreeney18882
Does this causes ear damageJoseph Lewis31
Need help with picking a amp plzjaime alonso1
Electrical system upgradesCadillacDb10
Do you need a bigger sub amp? 1200 watss rms diamond audioSean Gibson3
Jl audio vs ascendant audioSiX2
HU volts higher than the amps volts???alteraudiousa3
What do you think Chauncey Brown2
Kicker solo XMark S2
Does this guy know what hes talking aboutgage ware15
Jake Hill and Caddi DB might can afford this Jake Hill5
WHATS THE BEST??????Jake Hill17
RE Audio Paperweights[Kéviñ_Previé]1
ID MAX 12 / 600 or 800 watts rms ?Blair Aus10
Stickies!!!Chad Lee2
Kia SedonnaChad Lee27
What is the average db range for most systems?bassman34
CSX vs W7Simon J Casey7
JL Audio SPL?Lewass14
Enclosure, mIn or opt? hrm?Mike6
3 spl jws 10Trevor Eaton7
Can't find itNOL1M1TSOLD1ER3
Type S better then R?Tyler10
Speaker wirebaseball11878
Wires...wires...WIRES!!!Brandon9
Lead me in Right directionTrevor Eaton12
Hi pitch eeeeeeeeeeeee!!!!dumfuk ted bill jill11
Treo FansStackn Bucks19
TREO SSi 12 99$!!!Jerrone Hornbeak6
7998, P960MP ??Brandon6
8 inchesJonathan7
Do you think we could get this started?!Jeff Loughrey8
My ampSmitty5
Lead me in Right directionRochester1
Rockford box buildin tipsTrevor Eaton4
Any suggestions.Adam1
Check Out the OLDSCHOOL gear!Avalanche1819
How big of wire do i need????ted bill jill9
Hook computer up to stereoLewass28
Usining 1khz sine wave? to adjust subwoofer?killerzracing713
My boxLewass2
CSX on EBayTyler12
Help need a setup pretty quickChris Person30
Is it possible to make a L shaped square port?Lewass28
Plz help amp troubleKevin30
Will my head unit handle the POWER??Lewass15
The different ways Bass hitsLewass25
Ys the other louderS.P.D1
SPL or SQL for rap/hip hop musicmikechec92
Types of Boxes <- check this out pleasemikechec92
Problems with my type r'sChauncey Brown11
Two different subs ok to run off 1 amp?mandie waghorn6
Clean voicePelon5
Is rockford fosgate goodCasey Wood29
Imao???Casey Wood7
Box checkalgirard15
W7 box builderTrevor Eaton3
Check it out tell me wat u thinkJay B.5
Sub changeoverCasey Wood10
Does this look ok for a SX12Terry640518
H2H festiva pair off! Come vote for me :-)...Casey Wood12
Does anybody here at ecoustics ride quads or dirtbikes?ted bill jill84
Under 20 hzPelon2
RE SE 10's & 12's SX 12Casey Wood11
Ported box for SX15marshall white3
600 watts to each sub?James Longo8
New WebsiteTrevor Eaton12
Avalanche TuningTrevor Eaton5
Wat do u think about orions? i want some good oppinionsRoy motha fu%&in .T4
Turn bass up on HU or amp??Trevor Eaton11
Ikesound.com ?killer12
