Can't find it
Username: Lexuscoop
Post Number: 875
Ok my anntenna haven't been working since october and my friend came over and helped me look for my anntenna power wire and we found it, BUT we don't know where it should hook up to. do you guys know what the wire would be colored or what i can do about this?
Username: Goatin
U.S.A
Post Number: 356
are you trying to figure out where to plug the anntenna wire to the head unit?
or are you looking for the anntenna wire all together if so it should be black thick wire.
Username: Lexuscoop
Post Number: 876
im trying to find both. i followed the anntenna wire but my friend said that it switched somwhere so that couldn't be it. i can't find wehre to get the wire from the HU and the actual anntenna wire from the anntenna its self
